In Pokémon Legends: Z-A, one of the more intriguing Pokémon you'll encounter is Hippopotas. This Ground-type Pokémon, with its sandy, tough exterior, can be a valuable addition to your team, especially if you're looking for a sturdy defensive powerhouse. In this guide, we’ll walk you through how to catch or buy Hippopotas and what to consider as you add it to your roster.
Where to Catch Hippopotas
To start, let's look at where you can find Hippopotas in the wild. Unlike many Pokémon that appear at random in various locations, Hippopotas has a more specific habitat in Pokémon Legends: Z-A. You'll want to head to desert areas or locations with sandy terrains, as these environments are where Hippopotas thrives.
Here are a few tips to help you find it:
Check the Desert Biomes: Hippopotas typically spawns in the desert regions of the game. These areas are often hot and dry, making them perfect for Hippopotas. Look for sandstorms or areas with sparse vegetation.
Nighttime Spawns: Hippopotas tends to appear more frequently at night, so if you're not having much luck during the day, try waiting until nighttime to explore these areas.
Catching Hippopotas
When you're in the right location, you’ll want to be prepared to catch Hippopotas. This Pokémon can be a bit tricky due to its Ground typing and sturdy defensive stats. Here are some tips to help you succeed in capturing Hippopotas:
Bring Pokémon with status moves: Moves like Sleep Powder or Thunder Wave can be incredibly helpful in making the catch easier. Lowering its health is also a must, but make sure not to faint it.
Use Ultra Balls or higher-tier Poké Balls: While a standard Poké Ball might do the trick, using an Ultra Ball or a Dusk Ball (if you're hunting at night) will increase your chances of capturing Hippopotas.
How to Buy Hippopotas
If you're not in the mood to hunt or if you've had no luck finding Hippopotas, there is an option to purchase it. In Pokémon Legends: Z-A, you can buy Hippopotas from in-game NPCs or special vendors that sell rare Pokémon for a set amount of currency.
Here’s how to buy it:
In-game Currency: You’ll need to collect enough in-game currency (PokéCoins) to purchase Hippopotas. This might take a bit of grinding, but it can save you the time of tracking it down.
Special Events and Markets: Occasionally, Hippopotas may be available through special events or limited-time market trades. Keep an eye out for these opportunities, as they might offer a cheaper or more convenient method to add Hippopotas to your team.
What to Do After Catching or Buying Hippopotas
Once you have your hands on Hippopotas, it’s time to prepare it for battle. This Pokémon has access to powerful Ground-type moves like Earthquake, making it an excellent choice for taking on Electric or Fire-type Pokémon. With its ability Sand Stream, it also summons sandstorms, giving it an edge in battle.
Here are some key tips to maximize Hippopotas's potential:
Evolve into Hippowdon: Hippopotas evolves into Hippowdon at level 34. Once evolved, Hippowdon gains better stats and becomes an even more formidable tank.
Consider Movesets: Focus on building a moveset around its Ground-type strengths. You might also want to teach it Slack Off for recovery during longer battles.
In conclusion, knowing how to catch or buy Hippopotas in Pokémon Legends: Z-A is an essential step for any trainer aiming to build a robust, defensive team. Whether you're lucky enough to catch it in the wild or decide to buy it from a vendor, Hippopotas is a solid choice with plenty of potential. Happy hunting, and may the sands of time be in your favor!
How to Catch or Buy Hippopotas in Pokémon Legends: Z-A
HeartIron46
- ma moto : ascdds
Message par HeartIron46 » lundi 17 nov. 2025, 08:46
Retourner vers « Débrider un 1000 FZR »
Aller à
- STAFF ONLY
- ↳ LA CHARTE DU FORUM
- MEMBRES DU FORUM
- ↳ Qui es tu FZR man/woman ?
- ↳ Ou se passe quoi
- LE FORUM FZR
- CAFE DU COMMERCE
- ↳ Liens internet !
- ↳ La vie du FZR
- ↳ vidéos motos et motards
- ↳ De la route à la piste !
- ↳ vidéos de fzr sur piste
- ↳ Les brèves de comptoir !
- ↳ vidéos diverses
- FORUM TECHNIQUE 1000 FZR
- ↳ Débrider un 1000 FZR
- ↳ Mécanique autre
- ↳ FORUM TECHNIQUE 600 FZR
- ↳ Débrider un 600 FZR
- ↳ Débrider un 750 FZR/YZF
- PETITES ANNONCES
- ↳ Recherches
- ↳ Ventes
- ↳ Dons,trocs,echanges
- ↳ LES MEMBRES S'ENTRAIDENT
