The Best Loadouts for Farming Super Credits in Helldivers 2 – Maximize Rewards With Smart Gear Choices
ElectricComet
ma moto : 21
Message non lu par ElectricComet » vendredi 14 nov. 2025, 04:02
If you’re grinding Best Loadouts for Farming Super Credits in Helldivers 2, you already know how valuable this currency is. Super Credits open up new Warbonds, cosmetics, and gear options, so having the right setup can make your farming runs faster, safer, and a lot more consistent. After many hours of testing routes, trying different armor sets, and swapping loadouts mid-mission, I’ve put together a guide that breaks down the most reliable builds for players who want to maximize their Super Credit income without stressing through every fight.
Below, we’ll go step by step through what matters most: the weapons, Stratagems, armor choices, and team roles that actually speed up Super Credit farming instead of slowing you down.
Why Loadouts Matter for Super Credit Farming
Super Credits usually show up in two main ways: as loot scattered around the map and as rewards for completing missions. You won’t be fighting bosses or grinding high-risk objectives—your main focus is moving fast, looting consistently, and staying alive long enough to extract.
That means your loadout needs three things: mobility, crowd control, and reliability. The Best Loadouts for Farming Super Credits in Helldivers 2 don’t necessarily use the strongest weapons in the game, but they excel at clearing trash mobs quickly, escaping tight spots, and supporting fast-paced objectives.
Loadout 1: The Speedrunner’s Loot Build
This is the setup I personally use when rushing through maps to collect guaranteed and random spawns.
Primary Weapon: Dagger or Liberator
You won’t be stopping to fight that often. The Dagger’s accuracy and the Liberator’s reliability make them great for quick defenses without slowing you down.
Secondary Weapon: Any Standard Sidearm
The pistol rarely comes out during pure farming runs, so don’t overthink this slot.
Stratagems:
Reinforce
Orbital Gatling Barrage
Jump Pack
Supply Pack (optional but recommended)
The Jump Pack is the all-star here. It cuts traversal time, helps you dodge patrols, and lets you reach loot areas without long detours. Orbital Gatling gives you a cheap, fast defensive option when you get overwhelmed.
Armor:
Light Armor with Sprint Boost
The faster you move, the more loot you collect—simple as that.
Loadout 2: The Safe and Steady Solo Farmer
If you prefer running missions alone, this loadout gives you survivability and flexible damage without making farming feel like a chore.
Primary Weapon: Breaker or Breaker Incendiary
Great for clearing swarms quickly, especially on lower and mid-difficulty missions where you’ll be farming.
Stratagems:
Autocannon
Shield Generator Pack
Eagle Cluster Bomb
Reinforce
The Shield Generator Pack is extremely helpful for solo players. It buys you time to pick up loot safely and dramatically reduces random mission failures.
Armor:
Medium Armor with Stamina Buff or Increased Healing
The key here is balance—you want solid survivability without feeling too slow.
Loadout 3: The Co-Op Farming Specialist
When you’re farming with friends, coordinating Stratagems can dramatically boost your efficiency. This build supports your squad while keeping yourself mobile.
Primary Weapon: SG-225 Breaker or LAS-5 Scythe
The Breaker is fantastic for clearing small enemies fast. The Scythe works if your team wants a more energy-efficient playstyle.
Stratagems:
Supply Pack or Guard Dog Rover
Eagle Airstrike
Mortar Sentry
Reinforce
The Guard Dog Rover is surprisingly useful when sprinting between loot drops—it handles small bugs or bots while you keep moving. Mortar Sentry lets your team secure an area while someone else loots nearby structures or outposts.
Armor:
Medium Armor with Explosive Resistance
This helps you survive your own team's airstrikes, which is more important than it sounds.
Loadout 4: High-Difficulty Farming Build
While farming Super Credits is usually easier on mid-tier missions, some players prefer running higher difficulties for more guaranteed rewards and XP on the side.
Primary Weapon: Anti-Materiel Rifle or Railgun
Great for deleting big threats instantly.
Stratagems:
Autocannon
Orbital Napalm Strike
Eagle Strafing Run
These Stratagems help you dominate dangerous areas without wasting time or ammo. They’re not the fastest farming tools, but they’re perfect for staying alive while still clearing efficiently.
Armor:
Heavy Armor with Damage Resistance
This is one of the few situations where heavy armor makes sense—tough enemies hit hard, and extra defense helps you stay focused on looting.
Tips for Maximizing Super Credit Farming
1. Stay on the Move
Most farming routes reward movement over combat. If you get bogged down fighting endless waves, you’re losing time.
2. Learn the Loot Spawn Patterns
Super Credits often spawn around points of interest like outposts, crashed ships, and hidden bunkers. After a few runs, you’ll start recognizing the patterns.
3. Avoid Unnecessary Objectives
Unless they’re fast and safe, ignore optional side objectives during farming runs.
4. Communicate With Your Team
If you’re farming in co-op, spread out to cover more ground but stay within reinforcement range.
5. Use Stratagems Proactively
Don’t wait for a wave to overwhelm you. Drop sentries early and call in Eagle airstrikes before enemies get too close.
The Best Loadouts for Farming Super Credits in Helldivers 2 depend a lot on your playstyle—whether you rush, fight steadily, or prefer playing with friends. The goal is always the same: move efficiently, stay alive, and collect as much loot as possible in each run.
With a good loadout and a bit of practice, you’ll be unlocking new Warbond items and crafting stylish looks in no time. If you're still refining your farming route or want help building your own loadout, feel free to ask—I'm always happy to share more hands-on experience from the field.
