CoProcess 2.7.2 crack license download working tested
asksoft
ma moto : yamaha
Message non lu par asksoft » dimanche 15 juin 2025, 01:23
CHCNAV CoProcess 2.7.2 full crack version download
CoProcess 2.7.2 crack license download request by email to:
asksoft@Proton.me
Advanced LiDAR Data Processing Software
https://crackeddownload.com/product/cop ... k-license/
Highlights
CoProcess, developed by CHCNAV, is a powerful software solution tailored to the post-processing of massive point cloud data. It seamlessly processes field-captured LiDAR data into a variety of multi-format deliverables. With features such as point cloud management, measurement tools, and advanced visualization, CoProcess is an essential tool for professionals in urban planning, infrastructure development, and more.
I. Terrain Module
Scenario-based parameter settings, DEM is generated with one click, no manual intervention required in the process;
Automatically generates contour lines and elevation points, results can be directly imported into CAD drawing software;
Elevation verification: users can import check points to perform quality checks on the DEM.
II. Road Module
Supports importing centerline data from various design file formats (e.g., Haidi, Weidi, CAD, etc.), automatically generating cross-sectional and longitudinal profiles;
Cross-sections can be adjusted based on adjacent sections and point cloud data;
Section results can be exported in multiple design formats (e.g., Weidi, Baitu).
III. Volume Module
Supports multiple volume calculation methods: grid method, cross-section method, TIN (Triangulated Irregular Network) method; results can be directly output as reports, CAD files, and more;
Stockpile volume inventory report: compares two sets of data and outputs a comparative volume change report between the two periods.
IV. Intelligent Extraction Module
Powered by AI algorithms, provides fully automatic and semi-automatic intelligent extraction tools, enabling rapid extraction of over 100 types of road features and surrounding components, automatically populating spatially related attributes, significantly reducing manual measurement and data entry tasks.
Automated modeling: based on extracted road and component vectors combined with point cloud data, automatically constructs the road surface and completes 3D scene modeling.
CHCNAV CoProcess 2.7.2 is a professional GNSS data post-processing software developed by CHCNAV (China Hi-Target Navigation Tech Co., Ltd.) , a leading global provider of high-precision GNSS solutions. This software is designed to process raw GNSS observation data collected from CHCNAV receivers to generate highly accurate positioning results for applications such as surveying, mapping, construction, deformation monitoring, and geoscience research .
CoProcess supports various types of GNSS data processing including static, fast-static, kinematic (RTK/PPK), and network RTK modes, making it ideal for both field surveyors and technical professionals requiring precise coordinate determination.
Key Features of CHCNAV CoProcess 2.7.2
1. Multi-GNSS Support
Supports GPS, GLONASS, BeiDou, Galileo, QZSS, and SBAS systems.
Enables high-accuracy positioning using all available satellite constellations.
2. Flexible Data Processing Modes
Static / Fast-static : For control networks, cadastral surveys, and high-precision point determination.
Kinematic (PPK/RTK) : For mobile mapping, UAV/drone surveys, and vehicle-based applications.
Network RTK : Supports VRS, FKP, and MAC correction formats from NTRIP networks.
3. Automated Base & Rover Pairing
Automatically identifies base stations and rover sessions from imported data.
Simplifies large project workflows with batch processing capabilities.
