Complete Diablo 4 Across the Threshold with U4GM Season 14
Blustery
ma moto : 2020
Message par Blustery » samedi 4 juil. 2026, 09:11
If you've just stepped into Season 14 and found yourself staring at the Across the Threshold quest with no clear direction, you're not the only one. The first thing to know is that this seasonal chain only exists on a Seasonal character, and it quickly starts pushing you toward Realmwalker content, better loot, and more chances to pick up Diablo 4 Items that actually matter once the grind gets moving.
What the quest is really asking you to do
Across the Threshold is part of the Death Awakening story thread, and it works a bit differently from the usual campaign steps. The game tells you to defeat a Realmwalker, but it does not always make that part feel obvious. That is where plenty of players get stuck. The marker can be misleading, and if you just follow it blindly, you may end up running in circles instead of finding the fight itself.
Where Realmwalkers show up
There are two solid ways to run into a Realmwalker. The first is through Surging Pandemonium Ruptures during Helltides. These events can spit one out at the end, but it is not a guaranteed spawn, so you might clear a few and still come away empty-handed. It is a decent route if you are already doing Helltides for materials, experience, and extra loot, since you are not really wasting time. You are just stacking progress while you wait for the boss to appear.
The second option is the one most players end up liking more. Keep an eye on the world map for the Realmwalker event near Zarbinzet. It runs on a visible timer, so you can plan around it instead of hoping RNG does the job for you. When the event starts, head there, clear the fight, and stay put until the boss drops. That part matters more than people think, because the game does not always spell out what comes next.
What happens after the kill
Once the Realmwalker goes down, do not wander off. A portal opens right where the fight ended, and that portal leads into the Deathtoll Chamber. A lot of players miss this because they keep chasing the quest marker somewhere else. Really, all you need to do is step into the portal and continue. The chamber itself is a solo space with enemies, seasonal rewards, and the next chunk of the storyline. It is not a huge maze, but it can feel confusing if you are rushing and not paying attention.
For this stage, a lower difficulty can save you time. If your goal is just to move through the seasonal questline, there is no shame in dropping to Normal for a bit. You can always push harder later when your gear is in better shape. If the Helltide route feels slow, check Zarbinzet again and use the event timer. That is the cleaner way through, especially if you do not want to sit around waiting on random spawns. In the meantime, keep farming whatever you pass on the way, because the extra drops, materials, and gold all help later without forcing you into dead time.
Final Thoughts
Across the Threshold is really there to teach you the rhythm of Season 14. Beat a Realmwalker, enter the Deathtoll Chamber, and start building toward the better seasonal loop that opens up afterward. Once you get used to the event spawn and the portal that appears after the fight, the quest stops feeling awkward and starts feeling like part of the normal grind. From there, you can keep running Realmwalker events for reputation, materials, and stronger loot, while also building up Diablo 4 Gold for sale through steady play and putting yourself in a much better spot for Torment and the endgame push.
