Aim Under Pressure — Winning Gunfights in Real Matches
Le coin du pistard...!
jornw
ma moto : Honda
Message non lu par jornw » vendredi 16 mai 2025, 12:35
So you’ve got the bo6 bot lobby service perfect settings, a solid warm-up routine, clean recoil control, and elite crosshair placement. But here’s the real test:
Can you aim under pressure?
Because let’s be honest — when it’s a 1v1, final zone, and you hear footsteps around the corner, all that training goes out the window for most players. But it doesn’t have to.
Here’s how to bring your aim into real games — when it matters most:
1. Slow Down Mentally
Panic is your worst enemy. When you feel the adrenaline spike, don’t sprint into corners. ADS, pre-aim, and take your time. Pros aren’t faster because they rush — they’re smoother because they don’t flinch.
2. Trust Your Muscle Memory
You’ve trained. You’ve drilled. Now trust your hands. Overthinking mid-fight leads to hesitation. If your crosshair is on target, shoot. Don’t second-guess.
3. Limit Unnecessary Movement
Jumping, sliding, bunny-hopping constantly throws off your aim. Use movement tactically, not randomly. Stay grounded when you shoot — your accuracy will thank you.
4. Play for First Shot Advantage
The first bullet often decides the duel. Keep your crosshair centered so that you can fire the instant you see movement. One good first shot beats five random sprays.
5. Review Your Gunfights
Watch replays or killcams. Ask: “Did I miss because of aim, timing, or position?” You’ll see patterns — and fix them faster.
